- Wed Jan 05, 2011 10:09 pm
#231628
Ok so since my recent post this is what I have done
I went to pull-a-part and got a full D16z6 intake manifold
Fuel rail, pressor regulator, TB, FITV, TPS and injectors all for $25
I removed my IACV and cleaned it, Didnt fix pulsing idle
Some resurch and found out it could be the Fast Idle Thermo Valve which is under the TB
I removed the FITV on my D15b and the screw inside was not threaded in, completly loose which should explain my idle.
ALSO when I removed the hose that connects to the FITV itself, Coolant leaked out..
Is coolant supposed to be in the Fast Idle Thermo Valve?
If coolant is not supposed to be in the Fast Idle Thermo Valve does that meen I have a blown head gasket?
