By Apexracing
#142288 if the cars not running hot then i don't see the problem, myfan rarely runs it does work but only after its been driven a few miles. run your heat on full blast and see if it kicks on, you need coolant to circulate through the heater core to properly bleed for air, best way is to let it heat up with the cap already off, also if you have a bad thermostat your fan wont come on.
By MG6
#142316 Thank you, I will try that.
