By hatchin06
#51733 what is the purpose for cams? if upgraded whats the purpose?
By SOHCivegra
#51737 more air in, more air out....... valve lift and duration. basically how much the valve is opened and how long the valve stays open.
By hatchin06
#51738 so is it worth upgrading the cams? can you really tell the dif?
By SOHCivegra
#51743 yes and no.
as long as you know what your timing will be, yes.
if you just wing it, no.
what engine are you running? any other mods to the engine? do you have a specific drivability style? this would be the first place to start in trying to decide what cam/ cam company you will be going with.
you have to also keep in mind of how aggressive you want the cam, somethign with huge lift and alot of duration probably isnt the greatest idea for a daily. you could do a mild cam for and eveyday street machine.
make sure you do alot of research from the companies on the cams.
i see that you are typing CAMS so i would assume you have a DOHC. Vtec cams are easy to get for a DOHC, SOHC engines are just the slightest bit harder to find. Now dont get me wrong, they are out there. But if you have a specific lift and duration in mind its not like a 350 CID where everyone and their mother carries a cam for it.
I found that have a reputable company do a custom grind it pretty cool and not to overly expensive. plus it makes the benefit of being able to design your own cam for your own setup.
By hatchin06
#51746 actually i have a sohc. lol its a d15b7 with i/h/e. only reason why i still have this motor is because it only has 69,000mi on it. i drive it pretty hard lol. so where would be a place to find one? what else would i have to upgrade with it or do i have to upgrade anything with it?
#51747 d15b7 wouldn't really be worth putting a cam in. You would only get a few hp at most out of a cam upgrade. Your best bet would be doing a mini-me swap to get a better horse power output, Plus get vtec :thumb:
By hatchin06
#51748 i would do a mini swap but i wanna run this motor till its dead first. so i just wanna know what i can do to gain hp till i do run it till its dead lol
By id3379
#51750
hatchin06 wrote:i would do a mini swap but i wanna run this motor till its dead first. so i just wanna know what i can do to gain hp till i do run it till its dead lol
take off ur headers :hehe:
By hatchin06
#51751 about 2 weeks ago one of the bolts had popped off my headers and i was running it with open headers. omg it was so loud. id do it if the cops werent so anal here lol.
By id3379
#51752
hatchin06 wrote:about 2 weeks ago one of the bolts had popped off my headers and i was running it with open headers. omg it was so loud. id do it if the cops werent so anal here lol.
i do it once in a great while, makes ur single cam sound like a swap :thumb:
By hatchin06
#51753 ya people here arent to fond of it? they like yelling and flicking me off when i do it lol. it seems like there is a power increase when they are off. is there?
By id3379
#51755
hatchin06 wrote:ya people here arent to fond of it? they like yelling and flicking me off when i do it lol. it seems like there is a power increase when they are off. is there?
well some people say it does and it doesn't, naturally i would think there is since there is no pipe's restricting the air flow and it goes straight out, otheres claim since there is no piping that there is no back pressure or something like that, but i feel a little more power when i run them open.
By hatchin06
#51762 back to the cam topic. would i have to upgrade anything if i do get one? what would be a good one to get?
By id3379
#51764
hatchin06 wrote:back to the cam topic. would i have to upgrade anything if i do get one? what would be a good one to get?
skunk2, you should get a skunk2 or aem cam gear to be able to adjust the cam when you tune it.
