- Mon May 03, 2010 9:33 pm
#191661
Warning engine may be very very hot if you just got back from getting the o ring
warning i bare no responsibility for stupidity this is only something to base your experiences on. something you could use to help you along the way....
Alright first thing is first
Tools
extensions
12mm socket wrench
ratchet
12mm wrench
flathead or snips to get the o-ring off
Parts
10w30 oil to lube o-ring
O-ring for the d-series unsure if its the same part number for the other
ones part #30110-PA1-732 O-RING (26.4X3.1) (TEC)
Had to get this at the dealership and was a couple dollars....
Alright first step get situated get teh hood open and just look familiarize yourself with what you are about to do this job is easy but also it can be easily fucked up....
Alright so now lets begin me i like to keep things easy simple and i dont want to cut my hand open or something like that yes sometimes you are going to get cuts but this is an easy job and shouldnt cause you much more than a few burns if the motor is running....
I first took off teh silencer (if you have a full stock intake you will have this part
Next i unplugged the distributor from the wire harness...
Next there are 3 12mm bolts holding the distributor in now unlike me you probably should use the flat head screwdriver or scribe a mark so that your static timing stay the same mine was off anyhow so i didn't bother.........
after takeing the dizzy off look at the tip that goes into the head this is your Distributor O-ring
I tried popping mine off and due to the mileage on it broke as you can tell from the picture this isnt normal if it was good then it wouldnt brake like that......
next after taking off the old dizzy o ring i went about cleaning wiping up oil etc.....
now to install the new ring
what you need to do is well just like any oil filter job you wanna lube up the ring with oil....what i did was use some 10w30 motor oil and just wet down the O-ring.
now what i did to install this is i went ahead and placed the o ring on the end right before it gets a bit difficult to slide over and i rolled it over the top and made sure everything was set in place and voila! installed
Now just reinstall the distributor and turn it over to make sure that its in the right spot tighten everything up and enjoy the thought that now your car wont leak oil from your distributor.
This is a very cheap and often overlooked part gotta say very happy with how eay it was done but heck its a honda lol so woot there you go now go out and do it....happy tooling!
Tools
extensions
12mm socket wrench
ratchet
12mm wrench
Parts
1980 volvo 242
2001 crv
2001 crv
