By rflindy89
#107806 Ok I finally got my D15B2 into my 1995 Honda Civic DX and everything is connected expect my Air Intake. My car Cranks but won't start. I personally think its not getting enough fuel. Also I do not have the four injector clips but they are on but come loose by barely touching them(maybe the cause?)
Any help is greatly appreciated
By RevinEK
#107867 start with basics, is it in time? (belt wise) firing order?, are the plug wires in the right order?, same with the injectors?, id also find those clips if u could, it deffently wouldnt hurt.
does it just whirl over? or does it cough and struggle?
By Classiccarsrule85
#107937 also check see if it has a engine light if its saying injectors its that fuel injector wiring you talked about but go slowly such as check for spark by plopping out one plug and setting it agaist a good ground good time to have a friend or family member around while you crank it for them to see if they see spark....then id check for fuel i do hope you switched over to obd1 injectors and stuff but yea anyhow you best bet is to see if there is fuel pressure in the rail easily done by taking off/loosening the bolt on the end and if it sqirts its got good pressure then id end up going after your injectors.....but who knows it could be a bad tb i.e. map sensor and tps or something
