- Thu Nov 25, 2010 3:56 am
#224570
what is the different in obd1 and obd2 and why does it matter?
- Thu Nov 25, 2010 7:48 am
#224593
On Board Diagnostics. Its what computer system runs which engines.
You have obd0 or "Pre-OBD"(correct term) which is a Mess and should be avoided at all costs(Normally on 88-91 Civics and Integras.) Its not uncommon for the Distributer to go out. I have friends who go through dizzys every 6-9 Months. To check engines code you have to pull out the ECU and look at a Flashing light. OBD0 also typically likes using Vacuum lines. Like I early said a Mess and should be avoided at all costs.
OBD1 Is the most popular OBD as its the easiest to reprogram your computer. Almost all hondas 92-95 Run OBD1. The 90-93 Accord are all OBD1 as well. OBD1 is Super Reliable and if something does go wrong its easy to check codes.
OBD2 has two sub versions, OBD2a( 96-98 ) and obd2b( 99-01+ ) After 01 Some Hondas went to CAN based computers and some stayed OBD2b for a while. Today all hondas use CAN based Comptuers.
OBD2 Does have good tuning options however most people will get a Jumper Harness to let them use OBD1 ECU's, Most of the time reprogramed into their OBD2a or OBD2b Cars.
You can take any Honda Engine OBD0,OBD1,or OBD2 and convert it to each other OBD's by exchanged Distrubtor, Fuel Injectors and Alternators with the correct one.
For example B20b's are only available in OBD2, you can easily convert it to OBD1 by using an OBD1 Integra LS Distrubtor(or using a DIY to swap guts with your OBD1 Dizzy) OBD1 Alternator from your D Series and your OBD1 Fuel Injectors. You dont need to worry about different injectors sizes as they are all the same, Honda just changes fuel pressure on different engines.
Hope this answers your Questions. I also edited the Title and made it a Sticky so it can help more Noobs.
