- Fri Dec 10, 2010 2:12 pm
#227120
my iac went bad. and i was wondering if neone makes a block off plate?[/b]
- Sat Dec 11, 2010 1:40 am
#227203
Make your own i made mine the other day bolted on and all in about a half hour.start by bypassing your lines.Then remove the cel bulb.Then get a peice of plate shape it out and use a peice of thin rubber for the seal.Tighten it up and done.
- Sat Dec 11, 2010 8:19 am
#227313
That's all good and fine if you don't mind your car revving up and down in colder weather.
Having a sweet mustache is half the battle.
- Sun Dec 12, 2010 10:57 pm
#227529
ok thanx guys. im just guna make one and seal it should do fine
