- Wed Oct 14, 2009 2:06 am
#150608
well i have to let this baby go so here are the specs
ls block with 84 mm eagle sleves
eagle ls vtech kit
cp pistons 9:5
pauter rods
blue printed and balance
b16 oil pump
b16 head, ported and polished, 3 angle valve job
skunk 2 springs,retainers,valves and camgears
stage 3 crane turbo cams, blox intake mani
aem fuel rail, gm 3 bar map sensor
exedy flywheel
cm stage 3 clutch
ls trans
quaffe lsd
t3/t4 turbo, tail knock off waste gate, greedy front mount intercooler
jdm center concil, rear disc brake, welbro 255 fuel pump 3 inch down pipe
the body is very clean has a few ding but no rust or bondo at all verry solid car
all this car needs is a good tunning and youll have a hell of a fast eg. right now it has a chiped ecu but is chiped for all motor so as soon as it hits 10 psi the check engine comes on so i dont even boost it but it runs hard
car is in illinois asking 7,200 obo you can reach me here or email me at
lopez286@yahoo.com
eagle ls vtech kit
cp pistons 9:5
pauter rods
b16 oil pump
exedy flywheel
cm stage 3 clutch
ls trans
quaffe lsd
lopez286@yahoo.com
74 corolla turbo/still working on
85 ae86
92 eg fully built ls/vtec (turbo coming soon)
85 ae86
