By Method
#61495 do other models (CX,DX,SI,VX) come with egr vavles, and the controllers?
mine car only came with the vavle itself on the engine. i keep throwing the code and it bothers me. i've tried looking in the parts cataloge, i haven't had luck.
#61498 Only the VTEC-E motors had EGR to my knowledge. If you're throwing a code for EGR, and you confirmed that you're checking the code right, then that means you have a VX ECU. Does your ECU say "P07" on it?
By Method
#61527 i have the p13, h22 motor. might have to look for a prelude controller, and wiring it in myself.
im checking the codes right, shove wire in the two holes, and count.
