By rushvillejdmracing
#49908 hey guys i just found this forum i have a 92 civic hatch back cx and i just got my gsr swap obd1 can you guys just tell me off the top of your heads what i need to do i think i use the gsr throtle cable am i right and anything else that my come to mind thanks
Phil Anderson :?
By B18cDelSlo
#49910 what all did you get with the swap?
axles? ecu? how many miles are on it?
You might want to change out the clutch while you have the motor out. I added a fidanza 7lb flywheel as well.
By k0rean4life
#49947 you will need the following...
GSR longblock
B-series tranny
B-series axles
shift linkage
B-series rear t-bracket
GSR throttle cable
GSR driver mount
USDM alternator ( BIG GREEN PLUG)
ECU
Wiring Needed...
Knock sensor
Vtec soleniod
Vtec Pressure
Secondary Butterfly
IAB
O2 sensor
Recommended to replace...
Clutch kit
Resurface flywheel or replacement
timing belt
water pump
tensioner
spark plugs and wires
Cap and rotor
Fuel fitler
GSR fuel pump or 195 Walbro ( not a most but helps a lot )
By andy63
#49949 i just borrow this thread a little, i have a Honda civic Vei. I dont know what u calls it in Uk or USA but maybe VX, anyway it is a Vtec thats supose to run low fuel. Anyway, can i use that Vtec solenoid to a B18 engine??
By k0rean4life
#49951
andy63 wrote:i just borrow this thread a little, i have a Honda civic Vei. I dont know what u calls it in Uk or USA but maybe VX, anyway it is a Vtec thats supose to run low fuel. Anyway, can i use that Vtec solenoid to a B18 engine??
You should be able to, You can with the vx. What color is the wire?oh yea one more thing you most likely have a three wire IACV. You will need to convert that to a two wire. Check that and see if its 2 or 3.
By RAKUN
#49984 this is a very good answer, i will take note for my gsr too
k0rean4life wrote:you will need the following...
GSR longblock
B-series tranny
B-series axles
shift linkage
GSR throttle cable
GSR driver mount
ECU
Wiring Needed...
Knock sensor
Vtec soleniod
Vtec Pressure
Secondary Butterfly
IAB
O2 sensor
Clutch kit
timing belt
water pump
tensioner
Cap and rotor
Fuel fitler
