#37337 OK so i was thinking this today when picking up a new drivers door handle, this can either be three separate threads or maybe a mod can put this in the general section either way it would work.
How 'bout we have a thread that is just a listing of part numbers, i know there are locations online where you can look up stuff, but sometime that is long and tedious, and not always the right part you want.
So i will begin, lets hope this grows into a fairly good size with lots of info.
Drivers outer door handle, Black = 72180-SR0-A02
By yashep
#37368 Gorveatt that idea is awesome, it'll be better if it could be done by categories, body, engine, etc, etc. It'll be a lot of time involve tho.
Since I've been working with my trans...
91206-PL3-A01- Oil seal (axle seal x2)
91215-PL3-005- Oil Seal (shift rod oil seal)
14400-P28-004- d16z6 timing belt
14520-P2A-305- timing belt tensioner
12251-P08-004- cylinder head gasket
11251-P01-004- oil pan gasket
90009-PH1-000- oil pan drain bolt
94109-14000- drain bolt washer (change every oil change)
There's a couple, as soon as I get more I'll post them. :thumb:
By JLau
#37407 This is the site I pull all my numbers from and actually order from em most of the time.....
www.hondapartscheap.com
Other sites like www.hondaautomotiveparts.com have their own numbering system.
A few steps to get there but it would be easier than filtering through a list here. Just an idea.
JLau wrote:This is the site I pull all my numbers from and actually order from em most of the time.....
Sweet i'm bookmarking that site as soon as i get home, that will come in real handy
Only downfall with that site is the same thing with the parts look up on the computers at Honda, it doesn't list accessories. like the optional audio console, or aluminum shift knobs.
#37430 hondapartsdeals.com list the consoles and armrests...
