- Sat Mar 23, 2013 1:15 am
#329214
I'm currently running tokico whites with skunk 2 coil over sleeves. I'm wanting to upgrade to something that will handle time attack, road course, drag racing and daily driving. But more daily driving and roadcourse. What would everyone recommend? I'm going to be running a mild built b20 vtec with b16 or itr transmission.
- Sat Mar 23, 2013 9:14 pm
#329277
Ground Control with Konis has always been the best bang for buck option on the market. Most setups aren't going to be a big enough difference over your current setup to be worth it.
I suggest your money is better spent on a tire temp gauge (pyrometer), bushings, adjustable swaybars, extended top hats (makes a difference with Tokico struts and gives you more travel), tires, alignment kits, aftermarket steering rack, wheels, weight reduction, roll center adjustment balljoints, chassis welding/bracing, and lightweight control arms.
