By mikecozza69
#141377 Theres another post on here by me, about teh civic not starting, anyway, I pulled the ECU now. It doesnt smell burned or anything.
So how can i test to make sure it is broke. bear in mind though, that i checked the engine check light, and the light stayed illuminated meaning there is a fault with the ecu.
thanks guys
By marvinp8700
#141378 some mechanics can test them but it is very pricey. depending on what ecu you have, in most cases it will be cheaper to just buy another one.
#141423 Put the ECU in question into one of your friends 92-95 Civics, Then see if their car will start.
chrono404 wrote:Put the ECU in question into one of your friends 92-95 Civics, Then see if their car will start.
yep that will tell you if your ecu is still good.
By mikecozza69
#141697 does it matter with the make of the civic, mine is a cx auto.
