- Sun Apr 05, 2009 3:34 am
#108402
If you have Vtec-E now your car is currently wired for vtec. All you need is a Complete B16 Engine/Transmission, B Series mounts, Easy ones to come by are from 94-01 Integras, UKDM EG's might have come with b16's, if so those mounts will work as well. B Series axles, and B16 ECU. You will also need B Series linkage, Be it from an Integra or B Series Civic.
You want to make sure you get a SiR II B16, the one from 92-95 as its OBD1, Making it a direct drop in and plug in, and bam your set.
