By civicboy
#60538 hey, i have finished the b16a2 converion on my eg, its running obd1 interior and engine loom, today after putting about 1.5 litre of oil and water in the radiater i connected the battery and then turned the key but i didnt started it, it was giving the engine light, then i tried the daignostic test with the paper clip, it gave a permanent engine light like before, then i tried starting but there was nothing no click or starting noise or anything, let me know what would be the problem, i am desperate to taste the vtec on b16, help me out please, thanks amer
By JDM EG
#60556 check ur battery...
By Classiccarsrule85
#61537 either check your battery or grounds thats what happened to me is the grounds killed it (not litterally) but you need every single one stationed on a good area or it wont even click or turn over...
By ee8
#61565
civicboy wrote:hey, i have finished the b16a2 converion on my eg, its running obd1 interior and engine loom, today after putting about 1.5 litre of oil and water in the radiater i connected the battery and then turned the key but i didnt started it, it was giving the engine light, then i tried the daignostic test with the paper clip, it gave a permanent engine light like before, then i tried starting but there was nothing no click or starting noise or anything, let me know what would be the problem, i am desperate to taste the vtec on b16, help me out please, thanks amer
i hope you put coolant in your radiator and oil in your engine? :)
solid cell can mean there is something wrong with your ecu. try an other one, p28 or p30.....
Honda service manual quote:
(Check engine light stays on Steady),The backup system is in operation.Substitute a known good ecu and recheck.If the indication goes away, replace the original ecu.
By civicboy
#61583 it wasn't the ecu, it was the ecu fuse, i have sorted that out, tried starting it, but no luck there's no currenct going into starter motor, i think it might be the driverside headlight loom as one of the wires from the starter connects on that loom, Amer
