By slm01
#60737 Whatup guys!
I'm trying to nail down exactly what went wrong and what needs to be replaced. I was on the hwy going 80mph everything was smooth until all of a sudden it lost power, sputtered a little, and then cut off. I then had to coast to the other side of the highway. I tried to start it and the starter sounded fine like it normally does, but it just wouldn't turn over. I had to then get it towed to my house and now I'm trying to figure what I need to replace or look at. I remember I had a similiar problem with an accord I had and whatever it was, it was a common issue on older Hondas when its really hot out. I'm in Ga, so you know its really hot down here. I dont remember if it was the main relay or something else. I know someone has experienced this before and would like some help jogging my brain to get this resolved.
#60738 Main relay. :thumb:
By slm01
#60745 Is there any chance it could be the ignition coil?
#60753 Where the feck is the main relay on our cars. Ive replaced them on EKs, just not ours. I need a new one too. Mine does the same thing off and on.
By Classiccarsrule85
#60906 They are right near the clutch pedal on the D.side kinda a pain to get to but they are there cant remember it might be either right before or right after the fuse box
By slm01
#61066 Ok, it was the ignition coil. Once I ruled out the main relay by listening to see if I heard the fuel pump priming after turning the key to the second position, I purchased an ignition coil for 60 bucks and began the installation. Once I took the distributor cover off, the rotor was the only issue. The screw to remove it was rotated to the left and I needed it to be top dead center in order to access it. I cranked the car a few times to allow it to rotate to the correct position. Once done I removed it. I swapped ignition coils, replaced everything, and it started right up. Tomorrow I will go ahead and replace the plugs and wires for the piece of mind.
Thanks again to everyone and all the responses!!!!
By biretsu89
#61222 I had the same exact issue with my vx.... just stopped going.... I got lucky and just bought a new distributor... and Wala!
