- Sun Jun 08, 2014 7:16 pm
#346275
]hi, i just want to swap a d16 over a d15b carbs with an inline fuel pump( i don't wanna change the tank) and i wanna run the p28 on the loom using a harness conversion. The only prob i have is the carbs are running on p03 ecu which it has only 2 plugs that are fitting straight on p28. the problem is that i'm missing one plug!. i've got the obd0 to obd-1 but is not plug and play only because i need to chop off the missing plug. any idea will be great.
p03 ecu only 2 plugs
now the 2 plugs they fit on p28 which if my car was obd-0 it shouldn't fit
[/img]
[/img]
cIvic eg4 ImpoRt D15b dUal carbs!
D16z6 conversion going on.
