By suspendedHatch
#184174 Get the SPRAY CAN of window cleaner and at least two towels for each window. Spray the inside of the window, wipe with one towel, and then polish it off with the other. You can verify if the window is actually clean when the sun hits it just right or at night when you see bright lights coming through it.
When you drive, use the fresh air and not recirculated air. The air conditioner can clear them quickly and this effect works even when you switch the climate control to full hot.
You'll still get them fogging up but not nearly as bad.
It's definitely not a hole in your car.
