By cycleplus - Thu Oct 12, 2006 7:09 pm
#146
I recently puchased a 95 civic Se 2 dr, which has some rust on the rear quarter panels. I noticed that the rubber strip on the edge of both wheel wells was somewhat loose and not a tight fit so I took it off and replaced it with some 5/8 strips from Crappy Tire that basically stick under the lip and then sprayed Rust Check on the inside edge. There is a little bit of rust on the inside of the edges on both sides and I was wondering if I should replace the strip with a proper honda one or just leave it as it is seeing as it is allready rusting anyways. The reason I am asking this is because the strips I replaced it with dont protect the outer edges of the lip that much and I am concerned that this will speed up the rust process. Should I be that concerned?
Thanks.
Thanks.
