- Sun Feb 24, 2013 4:56 pm
#327199
if you want to repaint the car do you got to strip the oem paint/ paint job down to the primer?? or should you go to bare metal and redo the whole thing?
- Sun Feb 24, 2013 4:57 pm
#327200
It depends on the amount of body work you want/need to do and the condition of the factory paint.
- Sun Feb 24, 2013 4:59 pm
#327201
wait why would the body work matter? if i was doing dents id strip it down around the dented area to metal, and then bondo + prime that area.
ok so say there was a few small dents every where. what would i do?
rustyrex wrote:It depends on the amount of body work you want/need to do and the condition of the factory paint.
- Sun Feb 24, 2013 5:03 pm
#327202
If the car looks like the surface of a golf ball I would personally want it stripped to metal. And the body work matters for that reason. If there are a ton if dents or even deep scratches its easier to strip the car all at once then do the body work instead of grinding each little area. Plus if you strip the car you know there won't be and compatibility problems between products. As long as you use the same manufacturer.
- Sun Feb 24, 2013 5:08 pm
#327203
nice that makes sense. ugghh but striping the entire car down to metal would be a pain!
id have to get a big ass grander huh? or could i hit it with really low grit?
but actually i was planning on taking it apart and doing sections i could just take some parts down to metal and some parts down to primer... and that would be alot easier.
rustyrex wrote:If the car looks like the surface of a golf ball I would personally want it stripped to metal. And the body work matters for that reason. If there are a ton if dents or even deep scratches its easier to strip the car all at once then do the body work instead of grinding each little area. Plus if you strip the car you know there won't be and compatibility problems between products. As long as you use the same manufacturer.
- Mon Feb 25, 2013 8:13 pm
#327264
Tbh I wouldn't bother stripping the whole car down to metal.
If you do have the odd dent or deep scratch you can sand to bare metal on those areas fill and then use a high build primer to get the paint level again.
The whole car would have to be sanded with a fine grit paper to "key" the surface - this helps the new paint to stick. There would be plenty of other prep , remove mouldings , cover glass remove lights, indicators, side repeaters back tape the window seals etc.... Painting is not easy especially using rattle cans because the paint is much thinner.
" If in doubt..... Flat Out " - Colin McRae (GRHS)
- Mon Feb 25, 2013 8:31 pm
#327266
yeah, rattle can is easy if you have lots of time + take each part off the car and paint separate. like the quater panel / door/ roof/ trunk/ rear bumper/ front bumper / door jam/ front fender/ hood/ u can give attention to individual part and then better work into each part.
trackEG4 wrote:Tbh I wouldn't bother stripping the whole car down to metal.
- Tue Mar 05, 2013 2:04 am
#327765
no don't have a compressor.
but sander and grinder is better b/c i would need to do body work anyways
so id get a tool that serves too parts of the project. I like old school style of body work anyways hand sand and perfecting opposed to quick "efficient" pro style fancy tools then done.
reaperstk wrote:U could go with sandblasting if you have a big enough compressor and wanted bare metal, and if you do have a big enough compressor you might as well paint it with a gun after
