- Thu Jan 31, 2013 5:38 am
#325295
I did my whole engine bay.
IT TOOK ME 5 BOOKS OF STICKER BOMBS
I would venture a guess at 2 books, 3 to be safe.
http://civic-eg.com/viewtopic.php?t=17714
here is the page I posted pics of it...
http://civic-eg.com/viewtopic.php?t=177 ... c&start=60
I would visit amazon.com
for stickerbomb book kit
heres the link
http://www.amazon.com/s/ref=a9_sc_1?rh= ... 1359610501
make sure you sand your fender down good, use a decent primer, let it dry good, then purchase some 3m spray adhesion
spray that sucker down spot by spot overlapping the stickers slightly over each other by about 1/8" to 1/4" you can carefully spray the back of the sticker or just try sprayin it on top of the other very little
you will have to make sure there is no glue left only stickers,
get a decent clear coat and put about 3 coats on it, let it dry a little between each coat. follow the directions of it...
then feel it once dry
if you feel little bumps from the layers of stickers you need more clear coat
once it feels good then wet sand it with 1000grit, wash it off, then look at it, it will look like crap and faded but you will see some shiny spots. get the 1500wet out sand it out good washing it off 2 or 3 times
then get out the 2000 grit
repeat above process
buff with your favorite wax and good to go!
"smoke me a kipper ill be back before breakfast" - ace rimmer
