- Wed Apr 08, 2009 4:41 pm
#109164
x2
I love Negative Camber, Helps so much in the Turns. Toe changes when you lower your car. Toe wear is what kills your tires. So when you lower it make sure toe is set to "0" and your tire life will be much longer.
This info has already been posted. Just wanted to back it up again.
2017 Chevy BoltEV DD |2001 Honda CRV SE
VegasCivic wrote:Get a good alignment . Toe kills tires x10 faster then camber. Depending on the tire itself will also determine the wear. Remember that
x2
