- Thu Jan 29, 2015 5:53 pm
#351412
You will not have to roll your fenders to run slammed (tucking a lot of tire) with those wheels I would recommend using a 195/50/15 instead of the 55 to get a little extra room. You will have to take out your fender liners or cut them in the front. If you have camber kits you will be able to set them to whatever camber setting you want. Remember to get an alignment immediatly and to have the toe on the car set to zero or slightly in.
And you are correct about not needing a camber kit to drive slammed. Your wheels will naturally camber in as you lower the car (Toe will be affected as well) YOU MUST CORRECT THE TOE TO KEEP FROM KILLING TIRES.
Instagram:
https://instagram.com/enjoymotorsportsWebsite:
https://enjoymotorsports.com
