#28009 what ever the tire pressure is recommended,
What tires do you have?
By tyke
#28011 BF Goodrich G-Force. I really don't know what's the correct tire pressure for this.
By tyke
#28013 is 32 psi acceptable? i live in a tropical area where heat and rain is always the weather.
#28014 er.. ahh.. lol i dunno i just looked on the BF Goodrich site lol i'd probably put it around 38 to be on the safe side. cause 12 psi is alot in difference
By tyke
#28015 ok! thanks a lot!
#28017 I have the same tires and I only put what the sticker on the door of the car says to put in the tires. Shouldnt really matter what tires you have, its should be what the car is designed for.
By LowTEC-Derbo
#28019 35psi is a good estimate on where to go.
I actually run 37psi all around during daily driving. i would drop the front to 30 when I go racing :)
By PetrolHeaD
#28058
tyke wrote:is 32 psi acceptable? i live in a tropical area where heat and rain is always the weather.
32 psi is just nice, i live in the tropics as well and i normally fill 33psi in the front and about 31-32 in the rear
#28060 I have the same tires on my car, and they are all set at 35psi cold for daily driving. On the weekends, if I know I'm gonna be doing a lil racing, the fronts are at 20psi. 8)
By tyke
#28379 thanks for all the inputs! :thumb:
Greasedmonkey wrote:I have the same tires and I only put what the sticker on the door of the car says to put in the tires. Shouldnt really matter what tires you have, its should be what the car is designed for.
i don't agree, if your putting way low pro tires on then the pressure isn't going to be the same as the factory tires. same if you put big mud slingers on a truck you would put the pressure recommended by the manufacturer which would normally be lower than stock.
Don't some tires have the recommended pressure on the side of the tire?
york62 wrote:Don't some tires have the recommended pressure on the side of the tire?
like every tire does...i always go by what the tire says...unless im at the track
