- Wed Mar 07, 2012 7:15 am
#297339
What about 16's ? And are 195 tires pretty wide ?
- Wed Mar 07, 2012 7:17 am
#297340
What about 16's ? And are 195 tires wide ?
- Wed Mar 07, 2012 7:21 am
#297341
16 would be good I really wouldn't go above that and 195 is pretty standard witdh Most people run 205 on 15's stock tire sizes on factory alloy wheels is 195 55r15
If you do 16 you will want since most 16's are 16x7 want at least 205 45 16
cesardavid wrote:What about 16's ? And are 195 tires wide ?
- Wed Mar 07, 2012 7:25 am
#297342
What about a thinner sidewall ? Like 30 percent ? Sorry about all the questions, I've never really reaserched tires haha
- Wed Mar 07, 2012 7:28 am
#297343
You can do 30 but depending on your area and the roads you will be driving that is not a lot of side wall that can handle the road. hit one good pot hole and it might pop or even bend the rim less tire could cause bigger problems. Stretching tires can cause the same issues, and you can damage wheels very quickly or even damage the body depending on suspension set up.
- Wed Mar 07, 2012 7:30 am
#297344
Oh okay I see, well I'll keep researching man thanks, also.. How do you post pictures here ??? Haha
- Wed Mar 07, 2012 7:31 am
#297345
You will need to use hosting site and then copy over the link to the picture and you see the Img button when you are typing you comment you click that once then paste the link from your pic and then click it again and it should show up when you submit it
- Wed Mar 07, 2012 7:39 am
#297348
What do you mean by hosting site ?
- Wed Mar 07, 2012 8:07 am
#297350
OH, I don't have any of those -_____-
- Wed Mar 07, 2012 8:22 am
#297352
[img] http://m.facebook.com/photo.php?fbid=33 ... 1066599342
Idk if it worked[/img]
- Wed Mar 07, 2012 8:35 am
#297353
Copy image location
have to make sure the [img]is%20before%20and%20the[/img] is directly after
cesardavid wrote:[img] http://m.facebook.com/photo.php?fbid=33 ... 1066599342
Copy image location
- Page 2 of 3
- 1
- 2
- 3
