- Sat Dec 20, 2008 9:42 pm
#84717
I see a lot of civics with rear disc brakes? I know that they would be nice to have but isn't your rear brakes only for your e-brake or am I way off?
hatchin06 wrote:I see a lot of civics with rear disc brakes? I know that they would be nice to have but isn't your rear brakes only for your e-brake or am I way off?
No brotha.
Rear brakes are functional everytime you hit the brake pedal aswell and also work with the ebrake.
Even with drums you still give pressure everytime you press on the brakes.
Master cylinder holds tha fluid, you press on the brakes, sends fluid to the proportion valve which runs lines to your front and REAR brakes no matter if you have rear disc brake or drums.
BoRIcuA y QUE!
