- Mon Sep 23, 2013 12:21 am
#336967
My setup
The kit come ready to bolt on only mods you need is trim or removed the back plate
Kit start at 575$ + shipping(included all new parts)up to 850$for 2 piece rotor + upgrated brake hose
Need 15/16 or 1"master cylinder
2 x cryo treat 11'1 inch rotor 24mm thick 4x100 or 5-114.3
2x 2 pots caliper whit 49mm piston(massive) bigger than 45mm odyssey,Crv 2 pots caliper
24mm caliper bracket
503 (aka itr,nsx,legend)high carbon metal brake pads
The better of that setup fit under 15"inch wheel
The initial bite is Just amazing no heat fade just a ultra performance setup
So far 11000km on the setup no problem no fade no bad vibration daily driver on summer + week end track
Just for comparation itr. Caliper have 2550mm contact area,2 pots nsx 2273mm,2pots legend 2585,the caliper I use 3769mm contact area
Mycar civic si hatch 1992 fully built d16z6 21psi on 20g turbocharger
Sorry for my English I am french
Picture soon
Picture soon
