- Sat Sep 24, 2011 2:42 am
#274131
ok so sense there is no diy write up to let you know what it consist of
here is mine: (also i believe drums should be the same you just have to remove alot of springs and crap)
jack up car and place on stands
take off wheels. keep e brake on for a minute!
take and with ebrake on remove bolts holding rotors on
next release brake and start taking off calipers
2 bolts for caliper
then the 2 holding on bracket sry no picture
after hold caliper away and take rotor off
notice dust cap in center ... just take flat head screw driver and pry open and remove
next youll notice nut ... pry away bend and remove.. also there is a locking tabbed washer ...use magnet and remove as well
now the hub is free .. one of mine came off by hand other i had to hit off
you may run into this problem.. part of the bearing had stuck onto the axle
i used air hammer like so
and walah!
old vs new
now push new bearing on by hand and reverse removal steps and bam
make sure to torque axle nut to 134lbs
#1 Member of CHANCE is HOMO club:thumb:
1994 civic dx hatch-sold
1992 civic dx sedan-sold
2001 ap1 s2000 -daily
2 bolts for caliper
and walah!
old vs new
