- Wed Mar 30, 2011 9:34 pm
#247174
cjw_89 wrote:cjw_89 wrote:^ yes but the lcas are way to long for our egs. And you dont need a 40/40 prop valve. My 93 si came stock with a prop valve like the dx/vx/cx. This mod is what deturs people from doing the 4 sic swap. The prop valve IS NOT NEEDED!
93 si hatch(came from factory with 4 disc)
False info. The prop valve on eg si's are for the smaller si brakes. Sorry!
any civic or intgra that came with rear disc minus the abs(iirc)
has a 40/40 valve and YES you do need it
if not ur rear disc is pointless
my 40/40 looks identical to my stock
and yes you need the ebrake/handbrake cables
and i believe the trailing arms are the same but the lcas are diff
