- Fri Feb 03, 2012 10:27 am
#293181
Ok for a 99 civic of any ej6,8 or ek model you will need these parts
Rear trailing arms from a 90-01 integra with e-brake cables and brake Calipers.
You can NOT use the rear control off any other model Honda they have a completely different rear lower control arm.
Now I everything else is up to you if you want to replace things or not. Personally I would replace the rear wheel hubs, brake Calipers and if you want the e-brake cables from a 99-00 civic si they will fit perfect underneath the car. It's hard to tell if things are working on a junk car so I always replace these things prior to installing them on anyone's car. Also I would replace the trailing arm bushing as well.
All the rest you can buy aftermarket like rear camper kit, rear lower control arms, and rear toe arms. But don't need to be replaced. But if you have every worked on the back end bolts brake really easy so take your time or have new on hand to replace stuff with. You can look at my build thread and get a good idea of all it takes to swap. Not hard just takes time.
95 EJ1 BG33P -
RC
95 EJ2 BG33P -
DRC
Coupe Crew #20
