- Mon Jan 19, 2009 3:03 pm
#90097
if you use integra rear disc's could you use the your stock LCA's or do you use the integra ones that came with the rear disc's?
- Mon Jan 19, 2009 5:17 pm
#90132
Either or, both the eg and integra ones fit so you dont have to change the lower arm if you dont want to
- Wed Feb 25, 2009 12:34 am
#98741
Love the write up... ill be using it to do mine sometime this spring when it gets better outside. I got the trailing arms from an EG6 (SpeedTech), drilled disks all around, MC from a 93 civic si and prop valve from DC2...
- Sat Mar 14, 2009 4:00 pm
#103181
Dont need the valve if your only swapping the rears, will change feel. If you swap front and rears it 's almost a requirement for drivability.
No to the valve and yes you must have the e-brake cables. The differ from drum and disc
Hope that helped
Hope that helped
- Sat Mar 21, 2009 2:24 am
#104707
An Awesome Write up Bloke!!!!
Keep in mind a larger m/c will give you a higher more solid brake pedal.
and you really should get the right proportioning valve.
- Sun Mar 22, 2009 7:25 pm
#104985
Mine were falling apart. Look for deterioration I suppose. I replaced mine because I was replacing everything else at the time too.
Energy suspension
Prothane
I know there are more but those are very common producers.
Energy suspension
Prothane
- Fri Mar 27, 2009 2:40 pm
#106121
I doubt you can get the energy suspension bushings at autozone. You can order them online.
http://www.energysuspensionparts.com did a great job. Got me my stuff in less than a week
- Mon Mar 30, 2009 5:44 am
#106621
No problem. Dont worry I didn't take them off my car to do that...extras
