- Mon Mar 16, 2015 7:17 pm
#352622
Will 97-01 Integra Type R rear LCA's fit my Eg hatch? i have drums in the rear still, and i'm gunna run with progress CS-II Coilovers. i mean i think it should but i dont know if i can definitly do it. Thank you in advance
- Tue Mar 17, 2015 4:55 pm
#352644
they will fit, but the type r integras use a different rear shock then the usdm civic. the civic has the bushing in the control arm, but the itr has the bushing in the shock, so make sure you get the correct coilover to match the control arm.
heres the difference between the control arms.
dimension wise they are the same. its just different shock mounting.
