By MarkCayabyab
#225152 So my very first after market item would be suspensions. And i was thinking what i should get?
As for coilovers, i was thinking of the GC/Koni yellow combination
but idk what else to get? I know you need sway bars, strut bars, and bushings but is that it? Help would be greatly appreciated!
#225155 GC wit the koni yellows are a really good set up
and id upgrade the drums to rear disc
and get front and rear camber kits there not really need but if u want to have ur tires last awhile then there a good idea
rear lca's and all that other stuff u mention should be about it :thumb:
By MarkCayabyab
#225156 k thanks man! i really appreciate it. And sorry, but im new to the car game so i was wondering what do you mean by drums to rear disc? and yeah i was planning on not getting camber kits. And what's lca?
#225159 its all good man, we all start off not knowing alot so dont be afriad to ask :thumb:
the rear brakes are drums, up grading to rear disc helps with braking
the reason i say that is since u mess with the suspension might as well upgrade
and lca's = lower control arms
By MarkCayabyab
#226236 Cool cool. So like what kind of LCA's are good? and what about strut bars or sway bars or whatever?
By OleFolk
#226240 The rear disk brake conversion is actually Highly recommended
You should defiantly do this if your upgrading your suspension
Look into subframe braces and struts too
Your suspension should always be faster then your car :thumb:
By MarkCayabyab
#226620 How do you upgrade to the rear disk brake? or do the rear disk brake conversion? and what are subframe braces? what kind of struts? i wanna make sure i get the right stuff because i don't make that much money.
haha thanks Ole Folk & 94_jdm_ferio!
By MarkCayabyab
#226770 thanks again 94_jdm_ferio, you've been very helpful :thumb:
but what kind of rears do you recommend?
#226773 thanks man im glad to help :D
what do you mean by rears??
the rear of almost any integra will fit
i have a 91 integra ls rear suspenson and disc brakes
but u can get the rear disc off 99-00 civic si
the eg's that come with them 94-01 integras but i have 91 so im gonna say the 89-93 teg rear disc will work as well
as for sway bar for the rear go wit a stock GSR or a Type R but type r involves getting a subframe brace
and for the lca's id go wit skunk2 or funtion form
stay away from blox lca's unless you plan redoing all the bushings
the blox lca's bushings sux ass
but its all what you perfer my set up is
91 teg rear suspension with rear disc
91 teg rear sway bar wit stock eg mounts
tokio blues shocks with no name coil sleeves
#226987 function and form and blox lcas are pretty much the same thing. as are most others out there. the only different ones, which are better would be function7 and skunk2. thought i wouldnt get anything other than function7.
