By ikon
#155893 my power steering resevior got low and i filled it but now every time i turn the wheel to the right i hear a really bad squeak sound coming from the front left wheel well. the only way i can describe it is like a door that needs wd40. any suggestions as to what it might be. my car is sittin on its nuts so im sure that has something to do with it.
By dawg316
#155917 tighten the belt. fill resoviour with correct fluid, turn wheel lock to lock slowly a couple of times, re check fluid
By ikon
#155931 i checked the belt and fluid but it sounds like something is rubbin or needs grease maybe? figured its my suspension...... :?
By Apexracing
#156020 pull the power steering belt and then see if the squeak is still there. you def have a leak if its loosing fluid, check all of your ps lines and the rack. other than that, is your suspension stock, and at stock ride height. lowering a car on stock worn bushings can put ecessive load on them and somtimes cause them to wear out, or at least heat up and loose lubrication. i would check them for wear, and proper lubrication. also check your tie rod ends as well. just some thoughts.
By ikon
#156038 the suspension is not stock and sees a lot of track time. right now its dropped to the point where i cant even pull out of a parking space without a minimum of five pionts of turning :lol: there are no leaks so i guess its my tie rods or the bushing. ill check both. thanks.
By dawg316
#156055 inspect the rack and tierod. look for play in the tierods and look for leaks around the rack and the bellow boots.
have you greased your parts latley ie grease nipple on bushings
By ikon
#156114 man i track the fuck out of it. trust me it gets drivin. but i will definately hit some stuff with grease.
By krunch
#159278 thats weird man, i got the same squick sound on the left side front aswell..... still on standerd suspension untill the weekend possibly sooner if i get my ass into gear :D ... was hoping it was just standered strut pissin me off. have you found your problem??
By ikon
#159366 ive been lazy but it stopped for a little bit but now it picked back up. whats wierd is it happened once i dumped my car. imma check the tierods and ill let u know.
By ikon
#160318 i greased the ball joint on the tie rod and its fixed :P. no more squeak.
By krunch
#161778 hahahah same!!!!! alot of rain for me and just dried out!!!!!!!!! lol :thumb:
