By goblin
#186265 park on a even surface. i notice my ed sedan front tire have 3" - 4" inch gap. But the rear have 1.5" inch gap.. the absorber is not leaking.. is the rear sprng losing its strength?? how do we know??
#186314 the only thing that affects ride height are the springs
so if the car is on a flat surface and on side sits lower then the other[on stock springs] then that spring is bad :thumb:
By goblin
#186318 if i pick up a spring from a junk shop or bought used springs.. any tips / ways knowing the spring condition??
#186502 not unless you actually put it on the car
but since 1 went bad the others arent too far behind
if i were you id get some adjustable coilovers or coil sleeves
or just some drop springs, u get new springs and it lowers the car a lil or alot if u got adjustables :thumb:
