- Thu Aug 18, 2011 9:45 am
#267975
Hi guys, hope you can help me out
I've just installed a Slimatic Lite car alarm on my 95 hatch. As you can see from the diagram below, it has two output wires (#6 and 8 white-yellow wires) to be tapped into the hazard light:
compared to other alarm brands which only have one output wire to be tapped into the Parking lights (the only red-black wire in the cluster)
now i'm wondering if i can directly tapped the two output wires separately to the left and right Turn signal light wires on the combination switch under the steering column cover, i believe the green-blue is for the left and the green-yellow for the right. Is it as simple as that or do i need to install diodes or relay? will this work on the civic? i know that euro cars like the bimmer has separate left and right signal circuits, that's why instead of the parking lights, gauge cluster and backlight their turn signal lights are the ones to blink whenever the alarm is operated
i really wanted my turn signals to blink with the alarm, i just hope my line of thinking is correct
will wait for your responses
Rob from the Philippines
