- Sun Feb 07, 2010 4:13 am
#173832
ok first of ylou need the wiring diagram of the car i believe they gave you a link to it.. and you need the manual of the car.. you tap the wires you need like 12volt ignition assessory etc. the alarm will tell you which wires you need..
as far as it being manual you have 2 options..
you can bypass the clutch electically not mechanically.. the clutch pedal has a harness with 2 wires you have to join those 2 wires together
the bad part about it is you can start the car with out pressing the clutch and if you have it one gear and remote start it the car will go...
the second option i dont think you will be able to do.. you basically have to ground the shifter and put springs on each side of the shift knob and use the ground auxilary that shuts off the remote start that way yo ucan only turn on the remote star when its on neutral.. but i think i lost you so you are better off with the 1st option but you have to be careful..
i pretty much just gave you the basic instructions if you need step by step let me know
