ECU, Wiring, Sensors
By egkermit978
#119868 1993 civic si. was trying to connect a radio the other night and all of a sudden my dash clock got alot dimmer and only is bright when i press the button. i took the radio out and its still dim. any ideas?
By 3kkl3sia
#119871 does the stereo still work?
check the fuses under the hood for the stereo and clock. its on the same one i think.
when i was putting a after market one in the power wire hit metal and blew the fuse and it went dim.
my best guess...
By d-mon
#119939 are your headlights on?
that's when it's supposed to dim.
By dawg316
#120061 check under dash clock radio fuse. then check the 7.5 amp backup fuse in the underhood fuse box
By egkermit978
#120090 headlights are off and when they are on its even dimmer. i fixed it but now the clock restarts to 1 everytime i shut off the car. what can that be?
#120208 Sounds like you wired your clock to accessory power. The clock wiring and the cigarette lighter wiring are connected to the radio.
white blue is constant power and should be connected to your aftermarket radio's yellow wire.
accessory power is red/yellow I believe. Could be yellow/red if my memory is backwards. This should be connected to your aftermarket radio's red wire.
Second likely option is that your radio's dimmer wire is incompatible. Just disconnect it, it's not necessary.
