- Thu May 21, 2009 3:20 am
#117968
I was wondering if someone can help tell me why my gauge and ac lights go off. I have to play w/ the dimmer to have them come back on but they go back out here and there. I also wanna know how to remove the ac knob casing to change a bulb that's out. thanks a lot...
You can pull the power mirrors/light dimmer/sunroof controls option out with a screw driver. If you go to a computer shop you can get a plastic stick, often referred to as "Black Sticks" commonly used by Computer techs when they tear down laptops. If you use one of them you wont leave any scrapes behind. They shouldn't be more then $5 USD
If slide a screw driver/black stick into the sides and wiggle you can get the whole unit to come forward, I am pretty sure there was clips on the sides you need to press in to get the whole unit out.
Once the pack of three pods are out you can remove the dimmer unit and replace it with another one. As long as the new one is a working unit it should fix your problem.
Good luck
