ECU, Wiring, Sensors
By froshtyv
#110273 Well the problem im having is that my passenger side main light wont come on,
I have a HID kit, i have 12v at the plug but when i turn on the lights the voltage goes all over the place and i just get a ticking noise,
I though first it could of been a bad ground so i brought a new one from the battery just to make sure, same thing,
Then i tapped into the 12v parker light and the light works fine but i want to get it working the way it used to be?
Anyone have any ideas?
It used to work perfectly i was taking out the ballast and buld one night and put it back in and i got the problem?
I just can figure it out?
The high beam works fine on the same light,
#110274 Disconnect the ballast from the working light, and put it on the broken passenger side. If the light comes on you have a bad ballast. Seen it happen a ton of times, and thats why I dont run HID's.
By froshtyv
#110290 THe light works fine when i bring 12v from my parker lights, so the ballast is fine,
If i do change te ballasts over from one sied to the other its teh same problem on the same side of the car.
I just cant understand how i have 12v at the connector then when i plug in the ballast the voltage goes all over the place wierd readings on my meter?
It cant be a fuse etc so im really confused?
By Gunni
#110420 u have a short circuit somewhere on the way. try laying another wire for 12v..
By froshtyv
#110463
Gunni wrote:u have a short circuit somewhere on the way. try laying another wire for 12v..
This what i was going to do. I would have to take a supply from my other light. But i just cant figure out that it worked fine before and now it doesnt? And when it stopped it did so in the space of 5 mins one night.
