- Fri Mar 27, 2009 4:59 pm
#106135
hi there guys and girls......... me car is all runing lovely now...but the fuel gauge has stoped working it was working the other day... is there a fuse on the car for is anywhere..and i have checked the plug on the sender give it a clean still no work work ...help me someone pleeeeeeeeeeeeeeeeeeeeeeeeeexxxx
- Fri Mar 27, 2009 5:37 pm
#106146
how is it broken? does it show that you have full tank all the time, or does it just freeze up in the same place and doesn't move anywhere?
- Sat Mar 28, 2009 6:16 am
#106236
ok, cause i forgot to put the grounding wire on a piece of metal in my civic and now my fuel gauge shows that i always have a full tank of gas.
maybe you should check the plug on the back of the cluster and make sure all wires are in the plug. better yet if you can swap a cluster with a friend or something you can eliminate a problem with your cluster/plugs. Than move on to the fuel pump and checking all of your fuses.
