- Sun Mar 01, 2009 3:39 am
#99586
im having a problem with my signal n hazard lights, they stoped working. at 1st only my rite signal would work n my left at times but now there both not giving any feedback. my hazards are also like this...can any1 help wit this plz???
- Sun Mar 01, 2009 3:56 am
#99590
mine dont work either i just figured it was because my wiring is all hacked up,sorry this dont help ya
- Sun Mar 01, 2009 4:03 am
#99592
Have you checked bulbs and fuses? if not check them.
Have you done any work on your car recently?
- Sun Mar 01, 2009 8:00 am
#99613
There's a good troubleshoot flow chart in the manual. But if you're lazy you could go to the junkyard and pocket a hazard switch and try that. If that doesn't fix it then it's most likely your combo switch. But I wouldn't go and swap that out w/out verifying it with a DVOM.
The turn signal relay is that big black fucker plugged in on the right side of your under dash fuse box.
