- Fri Sep 19, 2008 8:16 am
#70492
I need some help on an electrical project. I need to use the door switch, because I want the thing to go on with the doors opened. I took the rear left panel to look at the switch, and I found out that it is only one wire - either a ground or the opposite. But, I also figured after that, that I can't use only one of those switches, as it will go on with only one of the doors. So, where is the wire that goes to the light on the roof?
Drivin' a Honda Civic D16Z6 1994
