- Thu Aug 07, 2008 8:32 pm
#65065
VERY IMPORTANT!!!!
If you're going to wire a starter button into your car, make sure the button/switch is not a Normally Closed button!!!!
My live and learn example: Pick'd up momentary push button from Radio Shack... Installed relay ... did all the wiring ... installed the button/switch... with my head under hood and right foot in front of front right tire..went to connect battery negative....... as soon as terminal touches battery negative.....
STARTER CRANKS with MOTOR IN GEAR!
Again, make sure the switch is a normally open not normally closed switch.
