ECU, Wiring, Sensors
By MI_excoupe
#64710 After I shut my car off I can open the driver side door one time without it locking. If I try to open it a second time, it will lock the driver and passenger door. But I can open the passenger door as many times as I want without it locking the doors. Does anyone have any idea what this might be. I have already tried taking the fuse for the power locks out and it did nothing. Thanks in advance. Josh
By id3379
#64719 mabie your relay is going bad, try looking at it and testing the voltage or mabie u have some bad wiring and its shorting out, try another relay if u can.
By Ecc0
#64761 Depending on what alarm you have some of them have features which work only on the drivers side to lock the doors once you get out so it might be something to do with that.
I have a Clifford concept 600 and that locks the doors when I put the key in the ignition which I hate :x
