- Wed May 20, 2015 12:54 pm
#353829
Street tune with a wideband AFR sensor? Or the more common add fuel and timing I just picked up a laptop for the first time and wanna try moving these graphs around tune?
The reason I ask is because a street tune will typically be an experienced tuner using a known safe timing map from another car they have dyno tuned with a similar setup and then mapping fuel while you drive on the street under many different load conditions.
A lot of young guys go to their 'friend' who 'tunes' and he burns a chip with a map he downloaded online adds a ton of fuel, timing, and a 3500 rpm two step and calls it a street tune because there is no check engine light anymore.
Just be careful of what they are doing before you buy it there is a big difference. I do a ton of sidework from home and about 75% of the modified egs that come in have the second option and get upset when I want to charge them to put in a known working ECU before going any further into diagnosing an issue.
Instagram:
https://instagram.com/enjoymotorsportsWebsite:
https://enjoymotorsports.com
