- Fri Dec 30, 2011 4:51 am
#287661
There are six bulbs in brown sockets on the back of the cluster, you will just need to take the screws out of the trim piece and don't forget about the Hazard switch and pull the cluster out and replace the bulb. The are 74 bulbs you can get at any auto parts store or look at LED and order some I suggest replacing them all while you have it out. It happens to all of cluster and climate control units after awhile pretty normal. I not sure there is a diy but I might write one up tomorrow and show how to do the climate control and the cluster.
- Fri Dec 30, 2011 4:52 am
#287663
dimmer switches are known to go out on our civics. next time the lights go out tap on the dimmer switch and see if they come back on. i bypassed my dimmer to keep the lights from going out.
- Fri Dec 30, 2011 4:57 am
#287668
I would love one of these... as I have no idea how to get the climat controll out and my lights there dont work, and I have to kinda guess what I am pushing
also a little off topic. speedos go out often?
EJ1_MK wrote:There are six bulbs in brown sockets on the back of the cluster, you will just need to take the screws out of the trim piece and don't forget about the Hazard switch and pull the cluster out and replace the bulb. The are 74 bulbs you can get at any auto parts store or look at LED and order some I suggest replacing them all while you have it out. It happens to all of cluster and climate control units after awhile pretty normal. I not sure there is a diy but I might write one up tomorrow and show how to do the climate control and the cluster.
- Sat Dec 31, 2011 11:06 pm
#287991
Pull out the dimmer switch, unplug it, and jam a paper clip between the red and black wires. NOT THE RED/BLK wire. If that fixes it, permanently loop the red and black or get a new dimmer.
If you manage to blow your parking lights by grounding the red/black and not following directions (it has happened to me lol), replace the under-dash fuse.
