- Mon Sep 19, 2011 5:41 pm
#272838
Going to be installing some HID fogs on my hatchyy, But im curious as to what Kit I should get? When you buy a kit what exactly is it your looking for do the ballasts go out commonly on the cheaper kits? I know cheap bulbs dont last, but im more curious on the more permanent parts of the kit such as wiring, relay, ballasts and what not. I also plan to be doing retro headlamps as well so I will be needing 2 seperate kits correct? Is there some kind of special kit for fogs and some kind of special kit for For headlamps? Or can I just use any kit for both? I've read around a little bit and some say I should get a kit with a relay? Also whats the difference between 35w and 55w just the output of the bulbs? Do the ballasts need to match the bulbs in turn of wattage or are the ballasts universal and only the bulbs go by the wattage? Also read that you want a kit thats plug and play and I't going to throw any codes?
