- Thu Jun 30, 2011 2:53 am
#261630
so i bought a used 3 1/2" tack from a guy and seen it working before we removed it from his car, now when i went to hook it up i noticed the wire for the tach under the hood had already been tapped into from the previous owner, when i put my volt meter to it it shows 0.075V all the time whether i rev it or not?, i tried straight from the dizzy as well and nothing?... keep in mind that i took the tack not working out of the equation by going straight at it with the volt meter? ive use the meter in the past and it has been a sinch, my old cluster's tack worked fine but for some reason it wont read on the meter?
i dont know im lost haha, is there a fuse that might have blown from the wire being exposited under the hood?
i also noticed that the end of the wire had a sealed plug on it? is that normal?
It's my CIVIC duty to stay true to the D series
