- Thu Nov 01, 2007 3:23 pm
#28175
Ok.. I put the Del Sol back together the other day and my turn signals wouldn't work, nor would my Hazard lights. I installed new turn signal housings, and the corner lights do come on with the headlights. I didn't have my side marker lights hooked back up yet so I figured that was the issue. I hooked up the side marker lights last night and the turn signals still didn't work but the side marker lights are on, so I figure the Flasher relay must have taken a dump on me. We after an hour of searching for it, I finally found the flasher relay. It was stuffed under the carpet, and the rest of my relays were moved around in various spots... But I digress...
My real purpose of this is, while I was hunting for the relay I noticed that the fusebox said turn and it looked like a relay would/could be plugged in there but there is nothing. Should there be something there or is that because they just use the same fuse box on every car and the Del Sol uses a different external relay separate from the fuse box?
Racing Rice
- 1994 Honda Del Sol Si (Project Combat Honda)
